pishta
I know I'm right....
SB? The relief spring is behind the cotter pin or pressed in plug on the pump, They sell a "340" spring that is heavier for more PSI before bypass but anything above 40 psi at cruise or "10 psi per 1k RPM" rule is overkill and hurting mileage. High mileage oil probably has more detergents in it, nothing more.
