anvildraw
New Member
Can anyone tell me what kind of fasteners you use to mount the center console to the brackets?
I use sheet metal screws that are the right size and length. I found that out by trial and error. Not too hard to do. Just went to my local hardware store.screws - IIRC there are 4 of them
i'm assuming then that you had to grind the back of the brackets down so they weren't to thick for sheet metal screws of that small diameter??I use sheet metal screws that are the right size and length. I found that out by trial and error. Not too hard to do. Just went to my local hardware store.
Carl
The metal is close to 1/8" thick and the slots are punched out not cut outAren't the brackets made of sheet metal?
