The day I pay$600 for a drag link I might just kill myself. I'd spend$1000 to not not give someone that much money for oneClassic Industries (Coming Soon) can be a long wait also.
Do you have a Oxy/Acc torch? You can heat the pitman arm and Idler arm and bend them down for some added clearance. One thing do NOT quench the heated parts with water just let them air cool. That way you don't make it brittle. If your a little more into metallurgy look into anieling them after you get them bent. The biggest negative to this method is it may adversely affect your bump steer.
That might be better then cutting and welding it. Or maybe I'll drop the entire link down with spacers. Is that an insane idea for some reason?
Someone show him a picture of the slant and the V8 drag links he may already have a V8 drag link because he has a 64 and the V8 was an option, I wouldn't doubt some 64-66 slants came with V8 drag links.Swapping a 64 dart to a 360 magnum from the slant 6. I know I need to change out to the v8 drag link but I'm not about to pay that much for one. I don't see why I can't cut and weld the part I got and and thinking about going that route. Saw one guy shimed the engine up but I don't like the idea of that.
Is that for an early A? Even the top one doesn't look like for a slant 6.
Yep. The top one was off of my '66 Dart (slant six). Even the non-V8 versions have a bit of a drop to them.Is that for an early A? Even the top one doesn't look like for a slant 6.
Did you copy that from one our Mini Van friends post?everybody and their mom: ThErE's nO A-bOdY 8 & 3/4's!!!!111
presents stock a-body 8 3/4: meh. not interested. tOo MuCh MoNeY!!!!
then starts the: i'll find one in the junkyard. or the whole: back in '82 i traded Big Nose Bobby a 12'er of Schafer, two packs of camels and took his ugly sister on a date to DQ for one with a 3.91 suregrip that was blessed by King Richard Hisself!
Mine is very obviously a slant 6 link unfortunatelySomeone show him a picture of the slant and the V8 drag links he may already have a V8 drag link because he has a 64 and the V8 was an option, I wouldn't doubt some 64-66 slants came with V8 drag links.
Both of them in the photo are from 66 Darts.1966 only has one center link for 273 or /6. May be the top center link in the picture. Bottom one looks like my 64 V8 center link.
Hot rodders been doing these things for ever...Christ...the bad ideas keep on coming. Don't do this either.
For $600 I'd buy a badass dry sump system and free up a few ponies while I was at it
People also use chicken wire and newspaper as backing for inch thick Bondo too.
Don't mock temporarily permanently attachmentPeople also use chicken wire and newspaper as backing for inch thick Bondo too.
That's 1994 price !!$100 is more like what I figured it would cost orginaly.
I sold three over the last 10 years, the last one was 3-4 years ago. I got $125 for a nice one.That's 1994 price !!
For that price, I think I'll sell one of my NOS ones........
Yes, the S6 in the 63Are they actually different? I'm not an early A guy.
But I find it hard to believe that Chrysler would stock two parts when one could've worked for both applications.
Thanks great informationYes, the S6 in the 63
didn’t need a drop centerlink. Come 1964 and the V8 in the early As then you had a drop link. Toward the end of 1965 model year all cars started getting the dropped link. Of course there were some S6 cars in early 66 that made it off the line with the straight link. Probably using up what was left in the inventory.
