[WANTED] Center dump exhaust manifolds
65 CUDA
PHOENIX,AZ
Rating - 87.5%
7   1   0
Looking for center dump exhaust manifolds for my 360ci in my 65 barracuda, I have 04 dodge ram magnum rear dump exhaust manifolds but didn't realize that the outlets and piping will run into my kickdown linkage at transmission. Or set of shorty headers that have center dump exhaust outlets
Never seen center outlet manifolds for a small block. Summit has the center outlet block huggers for the small block, though.
Passenger side 340 manifolds dump in the center but to my knowledge you cannot run a center dump passenger manifold on the driver's side due to the exhaust pipe interfering with the steering box.
My 273 ci in my barracuda had center dump exhaust manifolds
I had two 72+ 340 passenger side manifolds that would have worked out then. I have one left if you want to go that route.
The A body never came with a driver's side center outlet. I don't think one will fit in his car, but he seems determined to try. Maybe he can make it work.
Id be more than happy to sell it to him so he can R&D it. I was going to use the pair on a D100 but decided to just do some long tube headers.
I looked at it real good up against my 73 Duster and if it would work it would take some very creative pipe work on a manual steering car.
Here you go, PM me if you are interested.
I removed these from a 1969 340 X head engine.
Very good shape
There are/were a couple sets of the mid to late 80's truck center dumps at the self serve yard on 27th when I was there on the 10th of this month. Easy pickins'!
Those are for a truck, looks to be mid 80s. Kim
I have no idea what they are from
As I stated I removed them from a 69 340 engine, I purchased the engine out of the car, they may have been swapped onto that engine from anything. I do know that they were bolted on to an X head and appear to be the correct exhaust port configuration.
The OP wanted a set of SBM exhaust manifolds all I did was met his request.
Who cares what they are off of as long as they work. That is up to the OP to figure out it's his money.
