CRAMAR
Hi.I have a 72 duster.I put a 318 in with schmacher mounts.I kept my slant six torsion bars.I ve had vibration when I take a left curve and I see that the center link is hitting the oil pan.Everthing was new when I did it.The center link for 67 -72 a bodys is the same for /6 and v8.I have superstock rear springs and the car sits high in the back and goes lower in the front.Should I try to find a drop center link or try to raise the front of the car.I sure could use some help here.I ve worked in a mopar parts dept.for quite a while,so When I say the center links are the same I ve checked the parts book.What do I do?
