1. Jason96R
    Jason96R Well-Known Member
    266
    5
    May 22, 2004
    Ohio
    Local Time:
    8:00 PM
    I just want to make sure I take off the right spring(s). You take off the overcenter spring(underdash on pedals), and is that it or do you also take off the spring that comes with the clutch service kit. I have heard of people just using a block of wood for the clutch pedal stop, how thick? I'm starting to get excited all I need is to get a slip-yoke from my brother-in-law, all parts to finish up should be here Monday, and hopefully I will get the car on the road(so I can spend more money to fix all the bugs that I know I will have). Later today I will drive around to find some carpet laying around for people to throw away, don't laugh I'm being serious. Anyway thanks for your help.
    Jason
  2. moparracer
    moparracer Well-Known Member
    318
    12
    Apr 24, 2005
    Maine
    Local Time:
    8:00 PM
    Yes all you need to remove is the overcenter spring. Be careful, that is one bad spring. You are going to love that clutch.
  3. Jason96R
    266
    5
    May 22, 2004
    Ohio
    Local Time:
    8:00 PM
    Removing that spring will be easy, it is just hanging there not connected to anything. Thank you for the help, had to make sure you know.
