Centerline Auto Drag / Lug Nuts with 7/16" LH Thread
360duster
Bavaria / Germany
HI,
i can get a set of front runners with SBP for the next race event….but unfortunately my Valiant still has got the stock studs at drivers side front.....7/16" LH. Anyone got some Lug Nuts for this combination? Don´t want to change studs yet...limited time.
must be like these, but LH thread.
Gorilla Lug Nuts 74177
Thanks!
Michael
You need to start a wanted thread.
Just like to check if such thing is available somewhere…..or if changing the studs is the only Option.
Michael
Only problem with not changing the studs, is the stock studs are too short, to meet NHRA/IHRA rules. The studs need to extend into the hex portion of the lug nut, by the diameter of the stud (7/16) The stock studs are not long enough to extend past the end of the hole.
Opps, just noticed you are from Germany, so your rules might not apply.
I'm not aware of anyone making a left handed 7/16 lug nut for a "mag" wheel, any longer. Might be quicker to change studs, then to find nuts.
thanks guys, seems there is no way around changing the studs. I´ll do a brake swap anyway this winter, so i´ll run my steelies.
Michael
