WARFARE
Hi Guys, just wanted to know your thoughts on switching to a HV oil pump in my 340.
Original 41,000 miles. While replacing valve seals I discovered a blown head gasket. (Compressed air) While the heads were off I had them hot tanked along with the intake manifold. Cylinder walls look good with very little ridge so am just going to bolt the heads back down. (Plan to do a complete rebuild at some time in the next couple of years) I also changed the timing chain while in there as well.
The engine is super clean inside. Pan is very clean.
My question is, is there any benefit to changing the existing oil pump to a HV type if it is just an occasional driver?
I have not pulled the old pump out yet to see what shape it's in but figured since the pan is off I would change the oil pump as well.
Thanks for your thoughts.
Pat
Pat
