('72 A833 i n my '68 383 Barracuda). I really ddi not notice any noise previously - changed out the reverse light switch and let it drain- topped up, maybe took 2qrts of Sta-Lube 85-90. Can this maybe be a little too light? It seems to be only in downshifting lower gears. Can feel a slight meshing (vs. real grind) for lack of better term. Opinions appreciated. Maybe just go with some heavier stuff and see? I do not know what was in there from PO. I will t ry to compare the two oils ans see if the old stuff seems heavy. thanks
