My Grandfathers mower has a 392 Hemi with a Flamethrower magneto. He uses 8 lighting rods off his barn for plugs.Autolites. NGK if nitrous. Champions are for your grandfathers lawn mower.
You use the 65's ?Autolites. NGK if nitrous. Champions are for your grandfathers lawn mower.
Dusty2 red Xed me.My Grandfathers mower has a 392 Hemi with a Flamethrower magneto. He uses 8 lighting rods off his barn for plugs.
by chance did you mean "AG22's" ? I'm trying to cross reference this to Champion and see the heat range. ThanksAR12’s
AR22’s in my old pump gas engine.
Thanks, I was searching and coming up with nothingHold on bad info. I shouldn’t post while eating AR3912 now. And it’s been a long time but I think AR3922 on pump gas. I’ll have to see if I have one laying around to double check the pump gas number
Autolite AR3912 Racing Plug
Lol! Back in the late 70’s I was given a YZ 400 dirt bike all taken apart (I was 12, wanted a bike and my dad sad get it t running) champions fouled every time. NGK fixed my two stroke delima. When the 273 in my 66 barracuda came home from the dyno it had Autolites in it. Owner of the shop who built it said easier to read and easier to figure out heat range.I've been using NGK's since my dirt bike day's. My old 250 Bultaco would load up the Champions, NGK's cured that problem.
I believe NGK made the first platinum plugs, we used alot of them in the dirt bikes in the 70's.
How much do you know about spark plugs? As in.. what do you know about plugs that leads you to believe there's an "upgrade" and what does "upgrade" mean to you exactly? What don't you like about the champions? Are you trying to find power in changing spark plugs..?..Mild cam, headers, 600cfm edelbrock carb, Mopar chrome ECU box Have Champions installed now and wondered if there's an easy upgrade.
