iw378
Back to work. Okay I just checked the voltage at the blue trace wire on the ign terminal with the key on run. Posiitve probe on batt pos and neg probe in the ign terminal. I have a reading of .36
This is a new regulator. While the car is running at idle the voltage across the batt is around 12.5. as I raise rpms the volts keep rising to about 15.
As far as testing the grounds if I remember correctly that was car running test with the neg probe on batt neg and the pos probe on the regulator mounting flange. With car running it is reading -.001 that doesn't seem right ?? I checked to see if it was grounded by putting the voltmeter on batt pos andprobe to the case and got 12.6 volts so it is grounded.
Where does the blue wire on the ballast come into play
for the hell of it I checked the blue wire there with the engine off and key on run test and came up with .45 voltage drop ?
Sory for the long just trying to be as thorough as I can
Luke
Luke
