Please detail EXACTLY how you checked for power
Key on? engine running?
With key on, engine off, and all wiring hooked up "as per normal" you should have
1--same as battery at the blue alternator field terminal. Again, all wiring hooked up, "backprobe" the terminal. If no voltage, you have a problem in the under--hood ignition wiring. That blue branches off from the "ignition run" dark blue, which supplies ignition system, regulator "I" terminal, the blue field, and a couple other components in some models
2--Green should be a low reading. For a quick test, unhook the green field wire, use a grounded clip lead and ground that disconnected alternator terminal. You should see a small spark in subdued light, indicating current draw. REcheck that you still have "same as battery" on the blue
3--Start the engine, watch the ammeter, and see if the ammeter goes up to charge. If not, crank engine speed up to simulate "low to medium" cruise RPM, and check voltage both at battery and at alternator output post. If battery is below 13.5, and alternator post is about the same, alternator is not charging. If battery is low, but alternator stud is substantially higher, then you have an open in the charging line/ alternator circuit path to the battery
