I once read that there were only 2 types of the round back alternators. One made approx. 36 amps, the other 42 amps. The difference was in their armature winding and the only way to sort them is to weigh them.
Not true. First off, alternators do not have armatures. Also, there are three significantly different variants of the roundback alternator -- or four if you count the '60-'61 Essex-built units that have wider-spaced cooling fins and a few other physical differences. The '62-'69 grounded-brush "single field" item is the one most people bring to mind when talking about roundback alternators. There was also the '69-only insulated-brush 60A unit (see
here and subsequent page), and the '70-'71 isolated-brush unit (see
here), commonly referred to as a "dual field" item and completely interchangeable with the '72-up squareback alternators which are also "dual field".
Except for the '69 60A insulated-brush alternator, within each type of roundback alternator there are multiple amperage ratings, ranging from 27A to 60A. Output is contingent on the rotor and stator. Then there are multiple pulley configurations -- single or double groove, diameters ranging from 2½" to 3½". Pulley diameter was selected based on anticipated engine RPM range in a given application.
The aftermarket doesn't sort them
It's much worse than that. The "remanufacturers" throw together any ol' rotor with any ol' stator, just whatever happens to be grabbed from the barrel. Occasionally you get a good-working set, but more often mismatched rotors and stators greatly aggravate the relatively poor low-RPM output characteristic of the Chrysler alternators we're talking about here.
idle voltage would be 13.2 That would support the car and maintain yesterdays battery having a stored amp rating of about 300 Shelf voltage of that battery would be about 12.4. Once you start upgrading to electronic ignition and/or adding stuff like higher powered headlights and a new battery with a stored amp rating of 550 or more you will need higher idling power. Shelf voltage of that battery would be around 12.7
You're right that increased electrical demand calls for a higher-output alternator to keep up with the load, which in turn requires circuit upgrades (see
here) but the amp-hour rating of the battery (or the cold cranking amp rating, or the cranking amp rating, or whatever you are referring to when you say the "stored amp rating") has no influence on the alternator required to keep it charged. The voltage of a fully-charged "12 volt" auto battery will be in the very close vicinity of 12.6v, regardless of its amp-hour (or any cranking) rating -- that is with the surface charge drained off by running the headlamps for 60 seconds or so with the engine off before taking a reading.
I can say my charging system shows 14.4 at idle. Idle voltage in gear with everything possible turned on will not drop below 13.8. Slightest increase in rpm sends that back up over 14.
That's quite excellent; your charging system sounds to be in good shape.
