Cheap Carter Fuel Pump?
Rice Nuker
Let the Coal Roll!
U.S.A.! Near Jackson CA
Does anyone have ideas about a basic good fuel pump?
Car will have a 3/8 pick-up in tank and 3/8 fuel line to engine bay.
Engine is a 360 HP Duster motor ('74) rebuilt. With Hughes mild cam, headers, rpm intake, intake adapter, factory TQ, 3" exhaust. 727, 3.55 suregrip. Going back into the Duster.
I was looking at this summit carter basic unit for 34 bucks. Says 120GPH, sounds like alot for the "factory" diameter line ports they have on it. 6.5 psi max. Just wondering if anyone has experience with this one or similar. My main concerns are quality and longevity and also if it will be plenty of fuel volume for the 360. Appears the PSI is correct.
Another concern is that it works with the factory TQ "fuel pump to carburetor" fuel line. Would be nice not to modify the line.
Link:
http://www.summitracing.com/parts/CRT-M6866/
Any advice or comments are appreciated.
Looks like the standard mechanical fuel pump. Summit list it for small block, but sure looks like the one I took off my slant six a few days ago (changing to electric).
I have this one on my car, http://www.holley.com/12-838.asp
it has screw in fittings so I could use AN fittings, the one your looking at has the conectors already installed and I think they are 5/16, which is oem??
I used to have a carter pump.
i ran the carter hi volume mech fuel pump ran it for 17 years on 3 diff engines and its on my 340 now had to change my fuel line to 3\8 from factory 5/16 then it worked really well i ran the tq carb this pump is also rebuildable but never had to yet
I had this problem with a Holley pump even though it's a big block it broke.
So I ordered this Carter from Mancini.
chucker54_2191_66709701
And they make them for small blocks. Not cheap but better flow.
chucker54_2192_83869734
Regulators are really not that much.
A holley one is less than $30.00
I know when I used a carter rebuildable pump on my 440, I had to use a regulator on my holley.
Thanks for the PN.
How many years / miles on the pump?
What type of driving?
What is your engine/ carb / car, basic setup?
The Carter pump at Mancini pump 120 gph and is only 6.5 psi max.
Carter M6902 Small-Block Super Mechanical Fuel Pumps
BACK BY POPULAR DEMAND!
The product specialists at Mancini Racing worked directly with the Federal-Mogul/Carter Fuel Systems brand team in bringing back these highly sought after mechanical fuel pumps that Mopar enthusiasts have been requesting for some time.
Both the Carter M6902 (small-block) and M6903 (big-block/Hemi) have the following features and benefits:
• 5.5 to 6.5 PSI
• 120 GPH flow rate
• Tough lightweight aluminum silver cast finish body
• Large full-flow valves
• Anti-float springs for high RPM operation
• Heat treated lever
• ¼” NPT inlet and outlet
• Housing is positioned for the many popular Chrysler O.E. fuel line routing but can also be rotated to accommodate different inlet and outlet
Looks solid. Thanks for the recommendation.
Spendy, I reckon. 110 US Green backs.
We have a carter similar on our RB, cant for the life of me remember what it is. On the Mancini Carter, I like the factory pressure, fuel line and the clockable option. Main reason I want mechanical is I dont like noisy humm and buzz electrics, more importantly if a mech fails, I drop in a used Napa unit while on the road. If an elec fails I better have a similar one in the trunk.
Re the Mancini-Carter:
How long does it last? Will it run 50K on street car? Do you have any feed back on this unit?
Much appreciated
• 5.5 to 6.5 PSI
• 120 GPH flow rate
Much appreciated
I just bought one and haven't installed it yet. All I can tell you is look at what happened to my Holley. I know I turned the motor 6000 rpm.
Don't let the 5.5-6.5 psi fool you on those carter street/"STRIP" pumps, i have run a few & the lowest one put out 8, my last one drifted to 10.5, you will need a reg. with those, Now Mancini does offer an HP Carter pump for "street" like the old muscle car carter pumps, those i think are rated at 120 but don't require a reg.
It seems better to rely on people's experiences than listen to sales people and read marketing literature, so thanks for the input folks.
bremereric thats the carter pump i was talking about 17 years and well over 100 thousand miles on a thermoquad and no regulator with no complaints
