cheap rear end parts?
greaserkid
Active Member
wichita, kansas
i have a 742 8 3/4 rear end that needs pretty much everything except the housing & axels
i don't have the best paying job in the world, so, what's a cheap place to get ring & pinion, drums, posi, all that?
and yes i've looked at jegs & summit
Probably be the cheapest to find a used posi center section with the gears you want on Ebay. Just be sure to check it out or have someone familiar with them to check it.
68gts340 said:
look around in all the junk yards in your area, you may be suprised at what you can find.
you would be suprised where you can find rear ends, 1/2 ton trucks, vans, full size cars, up to the 1973 model year
