slantin_77
Member
I have an engine from a 1969 Valiant with 80k miles on it and am wanting to turbocharge it and drop it in my '77 Dodge D100 pickup. I bought the engine and put it on an engine stand and don't know anything about it other than he said it ran like a top before he took it out to replace it with a 318 and that it only had 80k miles on it. I want to make sure it's stout enough to make the power the turbo will add, but I don't know if I want to do a full rebuild or just do the bottom end and maybe re-ring the pistons. I would like to do a compression check, but I do not have a starter so I'd have to do a compression check by hand, and that kinda scares me because the engine is so heavy on the engine stand that I would not want to have it tumbling down on top of me while turning the crank with a ratchet. Has anyone done this?
