Chip in rocker arm shaft pedestal
rick360
- Mopar Or No Car -
chester,ct
I was wondering if this head is ok to use when it has a chip like this out of the rocker arm shaft pedestal:
You might get a small grinder and knock down any sharp edges. That would be where a crack might try to continue. That would suck. After that, I would run hell outta it.
Yeah use it.
Get a sanding roll and smooth out that area from where the piece broke off. Then thoroughly clean it.
onig
That's what I was worried about,a crack, these heads are 40 years old and were kind of rusty, cleaned them up a bit and found that. I'm gonna take a grinder and smooth it out like you said and see if I can find any other imperfections. Thanks to everyone though. I plan running the hell outta it.
