Chucks 72 Demon Build
northeastmopar
Massachusetts
wanted to share some of the work. Installed the MSD distributor, wires, control and coil. Hope I mounted them in a good space. The wires are real nice and the boots are very nice. I am making my own wire looms as the valve covers have bolts which will not allow stock looms. I am also using a cable system for the tranny shifter. Hope it works well and I can finetune it ok.
I also got the stock fitting condenser for the a/c installed. Fits real nice into all the stock holes. Using a sanden compressor. car is a factory a/c 340. Also got a good fit on the aluminum radiator and ended up with an aftermarket fan. Hope it cools ok without the shroud. Heard some good and bad stories. Time will tell. The power steering pump seemed to fit ok considering it is the wrong type. A little tight but it works and all the belts seem ok.
Motor is a stroked 71 340 to 416. Never did one of these. My buds at MRL helped me choose the block interior. Just working the dash now, so I can fire her up.
Got my hood done but am thinking about some different paint schemes? Motor was a joy except for clearance issues with the Dougs headers and the power steering box. Very close, but I guess that is how they are.
Rear end and brakes all set to go. Upgraded brakes to 2 1/2" and bought new axles with the bigger bolt pattern.
Here is a close up of the rear brake assembly.
Bench assembly and resto of rear axle
Here is my restored and improved dash. I did away with the amp gauge and replaced it with a voltage meter. Did a total rebuild. New dash pad, metal painted with velvet black paint. New woodgrain and I had to add the indicator lights for the ebrake in red, the turn signals in green and the high beam indicator in blue LED mini lights. My Alpine blue tooth stereo/cd player will just be inserted into the already installed sleeve. I also installed 2 3.5" speakers in the top center OEM location.
Here is a close up of the gauges. You can see the LED indicators here.
Gauge's looks really good ...ever thought about converting the wood grain inlay to a Carbon Fiber look ? Just my opinion, but I think it would modernize the whole assembly.
Yes, I did think about it. The car has whats known as the Deluxe interior, which includes the woodgrain panel running down the interior door panels. I kind of thought I would like to leave the wood and a little of what belonged to the car when it was built.
I had to replace both lower quarter panels and also the inner trunk floor extensions and the small brace which gets welded inside the trunk. Both sides were weepy with pinholes, so we did both. Cut the panels below the body line and butt welded them together. I like to butt weld rather than doing lap welds as there is not place for moisture to collect.
LOL....Nevermind, you have AC and that would be your AC Condenser thingmajiggity in front of your radiator. I don't even know what AC is in my cars...lol All of my cars do have tranny coolers though and they are all in front of the radiators, so me being a knucklehead I made an assumption. Sorry
That's OK. The radiator guy told me the aluminum radiator would help cool the tranny fluid better than the stock radiator. So I did not figure I needed a tranny cooler. But who knows.
