67cuda360
I have noticed a intermittent "Clacking" sound coming from the driver side front, that goes away when I touch the brake pedal (even ever so slightly). It only seems to do it when I have driven the car for a little while.
I have checked the front end, just to make sure there wasn't anything obviously loose, and pulled the brake caliper off the rotor just to make sure everything was okay.
I noticed the brake pads don't have any clips that keep them centered on the brake piston. I assume this is the way it is supposed to be since it is the same on both sides.
Could the "Clacking" sound be cause by the brake pads moving back and forth while driving? I did notice the front wheels have some drag even when the brakes are not applied.
My car is a 67 barracuda with what I believe is a '74ish disk brake conversion, I think they might have taken the whole K-member plus connected parts from a 74 dart. (Looks like the lower ball joints are the 73+ style)
