rich006
Learning as I go
Any ideas how to get dirt out of the pocket inside the quarter panel skin, forward of the wheel? It's a '74 Swinger that will once again be my daily driver as soon as I finish this body repair.
Background: The rear window sits inside the forward part of the quarter panel skin. To deal with some rust in the lower part of that panel (where it overlaps the rocker panel), I cut open the quarter from the outside and found it's full of shattered window glass and dirt. The dirt blocks the drainage channels that should keep this pocket dry. I need to get that stuff out but I don't want to remove the whole quarter skin because there's a lot of good metal at the bottom (the rust is higher up, at the top of the glass/dirt pile). I think the pocket is too narrow to get a vacuum hose down there from inside the car, although I have already removed the back seat and the vinyl trim panel.
