cleaning the dishwasher...
pishta
I know I'm right....
Tustin, CA
The thing dripped out the gasket and I was checking the drain screen at the bottom. It was packed with crud so I removed it and cleaned it. It was mostly white flakes of the rubber the rusting racks are coated with. Found a lot more under it and packed into the water jet. I had not realized I had never cleaned this thing since we bought it....20 years! :eek:
My wife rinses all the dishes very good before we stack them in there so that would explain the lack of food crap in there.
I had a 15 year old GE dishwasher start leaking from underneath, turns out in their wisdom they used a rubber like material to make the entire underside where all the pumps etc connect.
It was disolving and had spring a leak. 20.00 later and it's good for another 20 years.
If you want to be grossed out... Pull the drum out of your cloths washer!
I been into this houses plumbing more than I'd like already. Agreed, hair balls pulled up with a drain snake are nasty.
