Rodzilla
I've done some clearancing on my stroker for the rod bolts/rods to clear at the bottom of the cylinder and also on the stud girdle. All the clearances on the block look good at 30-40 thou. And about the same on most of the girdle except a couple spots which are at 20 thou. Can I leave it there or should I take out some more material off the girdle?
