Clearance with aftermarket intake and 70/71 air cleaner
BuckeyeAlex
Jackson, OH
I’m looking at intakes for my 340 Demon and I want to run my factory air cleaner to stay as factory appearing as possible. What intakes have you guys been able to use? I assume anything high rise like an Air Gap is out, but is mid rise still an option?
Engine is currently out and unfortunately I didn’t think to measure how much clearance I had with the stock intake.
Keep in mind you could use a drop base for the air cleaner to gain back some of the clearance you lost with a taller intake
Here are some pictured in order as listed. Mopar performance ,Edelbrock performer, Weiand or LD340
Mopar performance
Edlebrock performer
Weiand
EdelBrock LD340
An LD340 is my top choice but I haven’t been able to find one yet. I didn’t figure a Performer RPM would fit, so that’s good to know! Which Weiand is that?
I have the same hood on my swinger and the air gap with 70/71 340 breather fits fine.
Im using stock spool mounts on mine and also have a 1/2" spacer. Its an MSD throttle body but I think its the same height as a carb.
have used the stock 70-1 aircleaner on Edekbrock performer, LD340, LD4B, Weiand Stealth. Used both Edelbrock AfB and AVS carbs, as well as Holleys. Edelbrock has a list of intake heights for their current offerings on their web site
Between this post and feedback on Facebook, I’m fairly confident I can run about any intake with it. Multiple guys have ran the Weiand Stealth and Summit shows it being slightly taller than a Performer RPM Air Gap. The only intake I could find taller than the Stealth is a Torker II.
Thanks for all the input!
