Edorion
Google Drive Link of Pictures
ARE281 50.00
ARE224 350.00
Cloyes Quick Adjust Timing Chain Set NS1, 150.00
Comp Cams 614-16 valvbe locks for 11/32 valves +.050" height 30.00
99378-16 Crane Cams - Hi Intensity Hydraulic Lifters 100.00
Summit oil pan gasket 30.00
90425 exhaust gaskets 10.00
Superformance M1 tunnel Ram gaskets 25.00 or buy the B engine manifold to go with them for 500
KEM fuel pump 25.00 NOS
Superformance timing chain gasket kit 40.00
New HD Ford trans cooler 20.00
727 Dipstick tube 10.00
440 Source crank pully spacers both for 25.00
Comp Cams Tool Steel retainers 200.00
Comp Cams 929-16 valve springs 180.00
Comp Cams 23-228-4 Hot Street hyd cam 240.00
Crane H-302 cam, never ran, just put in block 232-242 .504/.528 112 CL 150.00
Lunati Street solid roller 40230733 looks like Lunati is going the way of the dodo
"Excellent cam for street/strip applications. Has good mid range and excellent upper RPM, torque and HP. Needs 3500 RPM stall converter or 4/5 speed transmission, headers, 10.5:1+ compression ratio and 4.56 gearing. Rough idle.
3000 7000 RPM Operating Range
249/255 Duration at .050". 110 Degree Lobe Separation Angle
0.585"/0.600" Valve Lift Made in USA" 500.00
Comp Cams solid Roller 23-741-9 243/243 .550/.550 110 CL 450.00
Shumacher Torque Strap 125.00
Dynamic 9-1/2" converter, bought after refresh, no miles since 700.00
Eldebrock Torker bbm, B engine 150.00 No machining, stripped holes
Weiand B engine tunnel rams, 500 each No machining, stripped holes
Torker 340 125.00 No machining, stripped holes
Offy RB tunnel ram, with the "turbo-thrust IR adapters" 350.00 No machining, stripped holes
[edit]***Edlebrock Calibration Kit kits for Performer carbs, these work for Carter AFB carbs, and AVS carbs with minor mods.[edit]*** x 2 with the book, everything in there is labeled, take it all for 100.00
One set of Comp solid roller lifters no pushrod oiling, no offset- roll smooth no scuffing 250.00
One set of Comp soild roller lifters with pushrod oiling and offset roll smooth, no scuffing 300.00
I'll listen to offers, but this isn't a fire sale, and most of this stuff is new, in box.
Shipping is not included, will be actual cost. Cash, US Postal M.O. PayPal is accepted, Friends and Family ONLY.
I'll have all this and more at the CPW Fall fling on Oct 19. Contact me by PM, Thanks For the Ad Joey!
ARE281 50.00
ARE224 350.00
