Has anyone had experience adjusting the clutch on a speed when using the 1 piece Lakewood bellhousing? Since there is no access panel like on a stock bell, how is the clutch adjustment performed or verified?
You can adjust the pressure on the clutch by adjustment rod (threaded)from the clutch fork.It,s how I adjust mine and it,s easy.It,s getting the fork on the throw out bearing that was the hard part on my lakewood bell housing,do to the small opening.Good Luck!Has anyone had experience adjusting the clutch on a speed when using the 1 piece Lakewood bellhousing? Since there is no access panel like on a stock bell, how is the clutch adjustment performed or verified?
