matty wardle
mopar dedicated
i have just reassemble my front clutch drum with 5 alto red frictions and 5 kolene steels,its put together dry and i have 0.115 clearance to snap ring,in carl munroes book he says about 0.015 per friction which means it should only be 0.075,will this be ok and what are the ramifications of leaving it as is,cause i also read somewhere you can have up to 0.125 clearance in here......opinions
