If you're installing headers, for ease of installation, you'll want the powertrain as close to the stock location as possible.I know I've been asking...................
No headers...stock manifolds.If you're installing headers, for ease of installation, you'll want the powertrain as close to the stock location as possible.
Unfortunately, it's really hard to tell what's afoul with your single picture.
Maybe you could post some pictures of your engine and trans mounts. Someone may see something obvious to them.
Also, shoot a picture of your frame ball bracket. Maybe it's been relocated at some point?
In any event, try to get the bell crank "straight across in any view".
BTW, this may be an "optical conclusion" by me, is the engine perpendicular to the firewall. Your picture appears it's canted toward the passenger side.........
The SB guys will be better to answer this. There may be some spacing differences.Are there different engine mount brackets for different years, different cars, etc....? I'm using the brackets from a 1972-73 273 on this 71 318. Are there different engine mounts...different thickness..?
Thanks for the explanation. CRUZE 418 had mentioned this trying to help, but I misunderstood.Pix help a lot.
The front mounts appear new, but are thinner than I would have expected.
As was mentioned, the holes in the mount brackets and holes in the cast iron block are quite generous, so if you loosen the 3 bolts each side, just loosen lower bolt thru long slot of frame, piece of wood under balancer or pan, lift engine till weight off the mounts till they "dangle", use pry bar or similar to shift engine around till in best position. (link above)
The mount holes allow bolts to "wallow" around, allowing you a range of motion before tightening the bolts to block, lower motor till frame mounts touch, pry into best position by the chart posted earlier.
That should improve positioning.
If that doesn't raise it enuff, get some rubber mounts outta mid/late 70s small block p/up truck, or iirc van mounts.
They are about 1/4 inch thicker than car, and I use them often for header clearance.
Shims under the fr mounts is an option, but the truck mounts will prob be best, if the jacking doesn't work.
Keep in touch, you got this.
Good luck
I understand how it can get frustrating trying to help someone, a novice like me, that doesn't have the knowledge...sometimes even the terminology confuses me. You want to bang your head against the wall.
99.9 % of the people on this forum that I've dealt with, and there's been many due to my million questions, have been extremely helpful and patient and are always appreciated.
Thanks again..!
Your not talking down Inertia. It can be a fine line. Some people here give you all of the vegetables, but think that you know what to do with them. If you knew that, you wouldn't have asked. I am guilty at times myself, but try not to be.
