Clutch linkage Clips?
694spd
Upstate NY
When installing the horse shoe clutch linkage clips. Do they go around the linkage rods or do they mount outside the rods on the ends of the Z- bar studs?
It has been almost 30 years since I played with 4 speed and I'm having to relearn the details all over again...
Outside.......
If you're referring to these............
That's the one. In fact, I just took a look under the dash to check the one clip that has not been removed. The one to the clutch pedal and I see that it is attached on the outside as in your picture.
Thanks...
