I will measure and drill another hole to see the difference once I get my mount. Thanks for the help!
I'm in...nice job.
pay-pal coming w/ shipping address
Got it! Will be shipped out USPS Monday. Thank you!
I got mine. No disappointment and IMHO well worth the $$$
Hey @68 A Are you Steve Young on Facebook in the G3 Hemi Swap group? I think I saw this there, and I kinda want one. Been thinking about switching to hydraulic clutch.
Thank you Denny! That means a lot coming from someone that sells a reputable product!
You found me. The original production run had all of the mounts reserved. I have not heard back from everyone yet, I also have a waiting list if people back out/need to do a second run to meet demand. I will add your name to the list and contact you when I know I have one available for you.
Thanks,
Steve
I did not. Look at post # 28 & 29, you can see where I drilled the hole in relation to the spring tab that was cut off. Then following pictures of the linkage and clearance I had with the pedal depressed. I was getting the full stroke of the master cylinder without any interference. My car is not running, so as far as how the clutch releases, I do not know yet.@68A did you correct the pedal ratio like goldduster318 mentioned? How is it working?
Right if you don't change it the pedal stroke is reduced, making the pedal either never go as far down as it should, or it will sit much lower to the floor at rest. You will still fully travel the master cylinder. My main point is it's not anything like the OE pedal stroke and I don't think you'll like it. With the modification, its very hard to tell mine from a mechanical clutch linkage other than its a little lighter and smoother.
Hey 68A, hows it going? How is your project coming along, is the car running yet?I did not. Look at post # 28 & 29, you can see where I drilled the hole in relation to the spring tab that was cut off. Then following pictures of the linkage and clearance I had with the pedal depressed. I was getting the full stroke of the master cylinder without any interference. My car is not running, so as far as how the clutch releases, I do not know yet.
Great really want oneUPDATE:
I have contacted the machinist, will be ready to produce more within a couple months. I have a list of members here that want to buy from this run. I am trying to determine how many I should have made, if you would like to buy, respond here or send a DM please.
Price is $100, includes the aluminum mounting block, backing plate and hardware to attach to the firewall. I add a parts list for linkage to connect to the clutch pedal.
Thanks,
Steve
You are on the list.Great really want one
No, thank you.You are on the list.
Thanks
