mda440
Member
I'm in the middle of rebuilding my 727 and found the front clutch pack only has 3 clutch plates and the rear clutch pack has four. I've tightened up the clearances on the rear clutch pack, but I'm kinda worried about the front pack with only 3 discs. Is this enough for a 500hp big block? I'm using good clutches, but I've read some 727's had up to five discs in the front clutch pack??? Is this okay to continue rebuild or am I going to smoke this thing pretty quick if I install it???
