6 65Dart270Sedan Member Joined Jun 18, 2023 Messages 13 Reaction score 0 Location Tennessee Aug 10, 2023 #1 Can you use a slant six clutch and flywheel assembly on a LA 318.
Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 6,587 Reaction score 11,530 Location Wisconsin Aug 10, 2023 #2 The slant has a symmetrical flywheel bolt pattern, so the flywheel will need one hole welded up and redrilled to accomodate the offset hole of the small block's crank flange. You will need to use the early A (9 1/2") LA bellhousing.
