Clutch Return Spring-Easy Question
clifftt
Concord, CA
I cannot for the life of me remember where the outer end of the return spring is attached. Someone here must know!
Like this? That doesn't seem right. Isn't it attached in the other direction?
It's been 40 some years. It does not hook into the linkage hole There should be a notch or hole in the fork
My 70 duster has a slot on the TOP of the clutch fork where the spring sits in. The other end was hooked into a hole drilled into the ball stud bracket. I don't think that was the way it originally. I think the purpose is to keep the adjustable linkage from falling out of the clutch fork if there is too much play since there isn't a bolt on the end to keep it in. I put a stronger and longer spring in its place since I removed my over center spring and I needed more tension to pull my clutch up to give it some free play. Rog
Right you are!! I did not see that. Thanks!
................. I think the purpose is to keep the adjustable linkage from falling out of the clutch fork if there is too much play since there isn't a bolt on the end to keep it in.......
That, but mainly to pull the fork and TO away from the clutch fingers...................
Where it attaches on the fork...
