Clutch Rod and Pedal Problems
One thing`s for sure, it`s a jungle with clutch linkage parts for all the different combos. It`s almost impossible to know wich one to use unless you been wrenching with all of the versions.
Been there, had to call Brewers to get it correct. Just my 2-cents
Did you replace the clutch with a diaphram style pressure plate or does it have the 3 finger style as used by the factory. Diaphram style pressure plates will have a difficult time overcoming the pedal overcenter spring to get the pedal to come all the way back up.
