DionR
The Questionable Garage is doing a Demon build for all 3 of Holley's Grand Champion challenges using 3 different motors (Hemi, LS, Coyote) but the same car. Pretty cool idea, I like it.
He is using a QA1 coil over conversion kit, which completely makes sense to me with his 3 motor criteria.
What I am curious about is it in the first video (above) he makes the comment that the TB suspension is lacking in adjustment. I asked in the comments what it was missing in the way of adjustment and his answer was; "You can change ride height with the spring preload but you also end up loosing some spring preload to achieve that, so you can make quick changes but you can dial in a coil over way better".
Not questioning his use of a coil over kit, just (apparently) not understanding how coil over pre-load works. I did read one article on it and it sounds to me like tensioning the torsion bar when the suspension is on the stops is the same deal. And the only issue would be if the TB is too strong and/or the car too low resulting in the TB losing all tension when the suspension droops.
And the only reason to preload the spring is to make sure the spring doesn't move off it's seat at full extension, right? So no real handling benefits?
Am I missing something?
And just to be clear, I'm not poking at Jerad, just making sure I'm not missing something.
