salinasjoel
Learning Daily
I am taking out my points distributor and replacing it with a petronix system. I also got the flame thrower coil to go with it. I called petronix to make sure I was reading the diagram properly but I am supposed to remove the ballast resistor as the coil needs all 12 volts. I was going to mount the new coil and have been cleaning up my wiring as I go. The issue is that there is more coming off the ballast then just the coil wire. I then went to mymopar and looked at the wiring diagram and it has the same deal. 1 side runs in from the wiring block and out to the coil and the other runs in from the wiring block and out to the alternator regulator. My question is what should I do to run the coil wire without the ballast? Do I need to get a ballast just for the alternator regulator? If so what ohm?
Any help is appreciated
Thanks
Thanks
