inkjunkie
The following OPINON is my own. The torsion bar cross member is what supports the weight of the car from the factory. The top shock mounts purpose was to mount the top of the dampner, aka shock, not support the weight of the car. If you look at the picture you will see the car with the inner sheet metal fenders removed and the top shock mounts exposed. Now I can only speak for the a-bodies I have owned the top shock mount is in NO WAY connected to this sheet metal. What this means, in my eyes, is that if the upper shock mount were to see the weight of the car placed onto it it will at some point flex into the sheet metal inner fender. This inner fender is only spot welded onto the car. And where it is connected to the spot welded sheetmetal inner fender it is below the top shock mount, on a different "plane" if you will. Understanding a bit about leverage I fail to see how this flimsy arrangement is going to stop the top shock mount from flexing.
