Cold air intake.
Buford19
Kitimat b.c.
Cold air intake for gen 3 hemi swaps in a body mopar. Is the a aftermarket one that fits this application? If not any suggestions to building your own? Pictures and ideas would be appreciated.
this is what i did for my 70 javelin , opened up a hole in front of the filter as well as one into the fender for cool air not engine air. requires battery in the truck but should be able to do the same on an a body i would think
My fabricated box works great. The intake air temperature is usually about 100 deg F cooler compared to sucking underhood air. Much better for the engine. Ie less risk of detonation plus denser air= more HP
Jim
Jim
That’s good to know, I want it to be drawing cold air from somewhere. Was thinking about running my intake down by the front spoiler. Just not sure if I will have enough air volume ,if the pipe is longer. If not I will make a box similar to yours.
Take a look at what i built...
its on this page under hemi swaps.... i think the title is air intake tube size.... check it out
