Since you have water and electric lines in the same trench I recommend putting a yellow or red ribbon on the electric line. Or a few inches above it.
That's just me tho.
That's just me tho.
That's just me tho.
Insulate the trenches to keep them from freezing. Go well past the edges with whatever insulation you decide to use so the ground heat can keep the area warm enough to avoid a freeze.I'll do that, I am also going to mark the water "T" connection with an upright as it will need to be dug up later when a connection is made for the house supply.
Are you going to draw water from the pedestal? That is one area that will freeze if it gets cold enough and like said trailer needs skirts.
