collector assembly.
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
I tried looking for instructions but nothing avaliable for these. My question as you can see in the photos. Does the gasket go between the bracket and the lip or on the outside of the lip? I assume when bolted down this gap will close? Common knowledge for some Im sure.
If you go to advance auto or summit you can get alluminum ones that dont leak and are reuseable. Ive had real good luck with them.
Ok i had an issue. The ones that came with the hedman collectors the bolt circle isnt big enough. None of the holes line up with the bolt pattern on the collector itself. The inlet is the right size. So I went and got normal 3 bolt ones from advanced and they too are not a big enough pattern. Im not sure of the brand of collectors since they didn't come with the headers used when i bought them. Were there different sizes? What is the correct method of measuring them?
