[Found!] Column mount white plastic pieces needed
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
If someone has a bunch of these little white steering column plastic pieces or know where to buy them reasonably I would appreciate it. I have some I know but I can’t find them. This is for a 72 Duster column but I believe they are all the same for many years. Thanks in advance.
That's about what I have seen them for. There is a set on e bay I think cheaper.
I was hoping to fine someone that has a bunch of them so I could buy some extra ones. I need three right now.
Used are very brittle and usually break in two pieces. I would buy new. The last sets I gave to someone I put in an envelope and they were all broke in half by the time they received them.
Roy
I have some plastic and some metal
Eddie
Metal are pre 68. Do they fit the later column mounts tight ? I can remember having a column rattle and that was the problem. They were loose where they slid on and didn't squeeze like the plastic does. Just a thought from an issue I had.
