Column shift linkage grommet and bushing?
Mojoe9955
NJ
The parts in the photo came off a 69 B body with a smallblock and 904. I have a 74 A body smallblock and 904. According to info from the net this should work, but it will not as the diameter of the shift linkage is larger as is the hole in the shift lever at the bottom of the column. Assuming that I have the correct linkage which I am as everything fits up to that point. I'm not actually sure what that is. Any input on what that may be...source?
I have it jerry rigged now, but would prefer the correct parts
Thank you
