stroker402
1968 dart GTS convertible
wondering how much of an improvement will a stock 273 commando take before it won't climb anymore in hp/ torque ? would it be wise to go a few sizes larger with a cam? or did MA mopar have the specs right on ?
Ya but let's not go there.well, you could build it to "Super Commando" (D-Dart) specs and wring out ~275HP out of it but youll need to wind it out with headers. Youll lose low end. Is it a stick or auto? Mopar would not cam it past what the factory exhaust would handle
Well said. The things the Commando/Charger engines had going for them that made them rev, solid lifter cam,dual point, single plane intake and 4 barrel. The standard 2 barrel parts and hydraulic cam will run out of steam at a lower rpm. I think that's what the op was getting at. How far does it rev b/4 it runs out of steam. 5000 rpm. I'll run some numbers in a bit.Every cam is an exercise in compromise. A compromise between parts that support it, and needed results from it. The factory cams all make sacrifices to get good economy, service life, idle quality, ease of production, ease of assembly, etc. We replace cams to compromise some of that stuff to lean more towards a certain performance goal. Personally there's not any engine I would build where I would not upgrade from the factory cam . There is no reason not to.
Yeah,,,,,, that is one mean sounding cam , you wouldn't believe how many people that came up to me and asked if I had a big block in the cuda . Don't get me wrong with all the previously posts but the cuda had no problem turning over the tires at a roll so it was making some power and torque with the combo I had in it. I was just referring to in this post that if I were to install the 10.5:1 pistons in my combo it would add a few ponies to it and the big erson might strive from it . IMOYou must really love that cam...
That cam is not for your engine combo and a couple points of compression won't make it work.Yeah,,,,,, that is one mean sounding cam , you wouldn't believe how many people that came up to me and asked if I had a big block in the cuda . Don't get me wrong with all the previously posts but the cuda had no problem turning over the tires at a roll so it was making some power and torque with the combo I had in it. I was just referring to in this post that if I were to install the 10.5:1 pistons in my combo it would add a few ponies to it and the big erson might strive from it . IMO
I do realize the "MA MOPAR" has hit there goal when they built this commando engine in 1965.
Here's as close as I could come to a stock HP 273 with the cam specs I have. As you can see the HP tops out at 4500 and the torque peaks at 3000. You will also notice the Dyno program is pretty accurate. Stock HP was rated at 235 and the dyno rated it at 225.Well said. The things the Commando/Charger engines had going for them that made them rev, solid lifter cam,dual point, single plane intake and 4 barrel. The standard 2 barrel parts and hydraulic cam will run out of steam at a lower rpm. I think that's what the op was getting at. How far does it rev b/4 it runs out of steam. 5000 rpm. I'll run some numbers in a bit.
Just to confuse you even more, Here's a 318 with a Whiplash cam. It idles like a top fuler but over about 1800 rpm it smooths out and runs like a kitten. I have seen and heard the car after he built a 360 for it (so he could go fast). He liked the idle of the 318/Whiplash but it didn't perform like it idled. You could probably talk to a cam grinder and they could build you a solid lifter version if that's what you want.
I haven't heard of anyone that has. I would have to plug some specs into the dyno and see what happens.I know I've asked this before, never getting an answer, but, has anyone tried a Whiplash cam in their 273, Commando specs or 2 bbl specs??
