[SOLD] Comp Big Block camshaft...
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
New in the box Comp camshaft for big block Mopar. It is this one
http://www.summitracing.com/parts/cca-21-242-4/overview/make/dodge
The box is worn. The cam is new and unused. The cam card has been misplaced years ago. The numbers on the cam are correct and the parkerized coating is still new and fresh. The cam has been lubed and wrapped in newspaper. You can see a picture in the link up there ^^^^. This will make a really nice thumping cam for a hot rod, pro street or something similar. 100 dollars shipped in the lower 48. Located in middle Georgia.
Are those the new invisible lifters? lol
It will run well, but it will need a mild stall probably 2500-3000 and at least 3.55 gears. It's a pretty stout hydraulic cam. you can advance it down around 100 ICL and it will have all the bottom end torque you can stand.
Not sure on those lifters. I am not crazy about the lifters that use that chinsey wire retainer to hold the plunger in. I prefer the ones with the heavy duty snap ring. They are more expensive, but worth the extra money.
