Comp cage kit?
423dak
The main hoop should sit on the rear floor pan right? Hoop is about 3" too short. Fits great if i put it up on the rear seat hump. Is it safe to splice 3" on the tubes?
Here is the NHRA rule book. http://www.nhra.com/tech_specs/sportcompact/2008_SC_Rulebook.pdf
Should be safe but don't know if it will pass tech or not.
Way I seen it done s they take a tube that is the same OD and the cage ID. They slide that tube in there to span the gap in side the cage tubes leving a small gap then weld both sides and weld in the crack.
http://www.circletrack.com/safety/ctrp_0804_rolllcage_repair/photo_08.html
They do that all the time with buggys just don't know what the NHRA has to say about it.
Competition Engineering make a 2nd Gen A body specific kit. The main hoop just fits in. Maybe your hoop came from a different kit.
Very well could have. I bought it from a guy I know. He said it was for his duster. Doesn't matter, need to either get one bent or dd to this one. Is the roof short on a 67-69 Dart? I see on summit the application for the 70-76 doesn't show the earlier ones. Maybe this is why Buddy didn't put it in his Duster?
I can bend one up for you...but dont know where you live and what shipping would be. I am bending one up tomorrow for another member...let me know.
Thanks!
LOL, I'm in snowy Atlantic Canada. Not sure if I can get further from you. There is a local guy that builds very nice drag cars. i will call him this evening. Thanks for the offer.
