has nobody tried this cam?. thinking of this cam with a 10.5- 1 compression 340 with worked over x heads . victor 340 intake, 830 cfm holley, 4speed, 3.91 gears. any comments.
Arent comp and lunati mostly Chevy grinds? No thanks!
Find a cam manufacturer that utilizes the mopar 904 lifter configuration.
thanks Rat Patrol i am going to print that dyno sheet out .
thanks Rat Patrol i am going to print that dyno sheet out . Flyfish good info too. I have heard of other guys wiping lobes on some comp cams also. Some were i read oil with zinc is critical on breakin?. what do you think makes these cams fail. Your stroker makes great power do you drive that car on the street on occasion? MY Dart is 90% street car but i do like to go to the track as much as possible. I would really like to pull the 340 and build a stroker but hey you cant have it all i guess.
