So you don't believe Vizard who has tested 1000's of cams and lifters, that's not good enough for you? Or as Ramm said, none of the other leading engine builders use them? How many times do you see them used in engine build stories, and if they were so good, then just about everyone with a hydraulic cam would be using them by now. But guess what??? there not using them are they??? And there's a reason for that and you choose to simply ignore that reason....
All the new hydraulic lifter technology is going to less bleed down with lighter lifters and with way tighter clearances so they can perform better at longer durations and higher lifts, and RPM's but don't let those facts get in the way of some adverting you read in a car mag back in 1986 .You want to make your cam smaller all the way through the rev range? , then be my guest and use the snake oil lifters. Just don't go trying to push them onto some other poor unsuspecting sucker.
It's become plainly obviously to me that we are talking about a subject that is way over your head. Tell you what... I've just seen some electric turbos for sale on ebay. Why don't you go and put one of those on your car. Then you can have two secret weapons under the hood.
