Comp custom grind hydraulic roller cam. Ground on a billet core and with low side mains to be used with stock roller lifters (does not uncover the lifter oiling hole even with a 1.6 ratio rocker arm). 240int/248exh. Duration at .050, .394int/.363exh lobe lift, 108LSA. This cam went a best of 11.80 at 116.6mph shifting around 6500rpms in a 3400lb, 365ci, 4 speed car. Makes great power! Only reason for selling is going to a solid cam setup to turn 7k+ rpms. Cam was only used for one season, is in like new condition!
Cam is $250
Mopar performance hydraulic roller lifters. Used for one season only, all wheels turn smoothly, all plungers hold oil properly and dont bleed down. $70
Set of 16 Manton custom length 5/16 .085 wall pushrods 6.562 long with 5/16 cup top. These pushrods are oil through to feed oil to the rocker arm balls. Custom length work with the above cam and Mopar hydraulic roller lifters. Used for one season only, all in great shape. $80
Smallblock Bronze Distributor gear. This is a Comp cams bronze gear pressed and pinned onto a Mopar Performance drive gear shaft. Gear itself has about 1500 miles on. Very little wear if any at all, no shavings in the oil whatsoever. $70
Will sell everything as a complete package for $450 (would prefer to sell it this way). The cam alone is worth that money. PM me for more info and pictures if interested. All parts located in Toronto, Canada.
Cam is $250
