Comp cams pt# RP1622-16 273-340-360 8620 chromemoly 1.5 ratio Ultra Pro magnum rockers and comp hi-tech pushrods (these pushrods are for flat tapped hyd cam) . Everything is gently used. No damage or heavy wear. Pushrods are comp hi-tech pt number 7958 7.550” long. .080” wall was in a small block that got pulled to run a big block. no issues or problems, no modifications. summit lists this kit for $1200US
$675US plus actual shipping from BC Canada.
