[SOLD] Comp Mutha Thumpr Roller cam
Cuprum-74
Moparus Fanaticus
Utah
I have a used Comp Mutha Thumpr Hyd. Roller cam for sale.
For LA blocks, it has 5000 miles of use on it, all street miles no racing.
I replaced it with a Lunati Voodoo so I have no need for this cam anymore.
Asking $150 obo. + shipping.
Did you replace it with a Lunati Hyd Roller or a Solid Roller.....How well did the cam work.....Special length push rods too.....I'm interested can you give me more information on it.....Thanks Webby.
The lunati is hydraulic roller as well. This is a drop in for 1990+ LA blocks (like mine was) and magnums if using mech. Fuel pump. The cam worked good had ok street manners. This thing was designed for sound and a loping idle, However this thing only pulled 9-10 lbs of vacuum at idle. If you have manual brakes and manual transmission, this cam is a good fit.
