Comp roller rocker, need help
1970Duster
I have a set of comp roller rockers on x heads with stock 1.5 ratio and stock valve lift. Question is anybody using these under stock height (3.75 inches) valve covers? Need to order my valve covers but they are special order so either I get stock or tall (5.75 inches) so need to order right one. So anybody got input? Thanks in advance!
IDK about the stock covers, but they do clear the MP covers.
Nice because the ones I'm ordering are mp covers in cast natural alum
Make sure you order the small part package that contains the baffels and screws and gromets for the (Still not included) PCV and crank case breather.
I had some Comp Pro Magnums on my 360 in my 65 Valiant with stock steel 273 covers. They fit fine.
I think they are about the same size as hughes...which fit under my MP valve covers
